Canon ir5185 can`t see Fiery
  • Phil the copy guy
    • Sep 2009
    • 36
    I Have a 5185i with fiery box on back.The printer ststus menu just say`s
    check print controller box power and connections.It never recognizes
    that the box is installed? I`ve heard of the boot rom kit but have never actually seen or used one!
  • SCREWTAPE
    • Jul 2025
    Well the fiery issue could be a couple of things, firmware, memory,hdd.
    Check cables also. Does the fiery boot up properly, there should be two zeros. There is a kit.
    • Phil the copy guy
      • Sep 2009
      • 36
      Canon ir 5185
      Yes there are 2 zeros.How many cables conect fiery to copier
      • SCREWTAPE
        • Jul 2025
        Three, one is a crossover cable that connects to the machine port and one ethernet cable whichs connect to your network. On the fiery there are two icons ingrave on the fiery, one looks like a printer, this is where the crossover cable goes then the other end connects to the main unit. The other icon looks like a network icon this is where you connect you ethernet cable. The third one is a interface type cable that connects to the main unit.
        • costd
          • Jan 2008
          • 409
          Ah, yes. After being down for a bit over a day, I was asked to lend a hand since I am "the network" guy. First thing - check the cables (90% of the time it is a cable issue). He had the cables switched. Written instructions were ignored, pictures did not work, what ?? - color code or scratch & sniff lol
